90 hp yamaha ***/trim hydarulics not working
New here so any help would mean alot. Bought a 15 ft trihull with a 90 hp yamaha. The day i picked it up I went to raise the motor and the pump motor runs but no hydraulics. rams are clean and free moving (had to cut the line to get the pressure off to manually lift motor). Did not see any milk at this point. I did see what I thought to be a resevoir with a plug. The oil was a little low but not much. Worst part is finding the lines to replace the one I cut:mad: However here is the model number I found 90ETLH and 6H1E . Guess I can finish the floor as I try to figure this out. Any help would be be great. Thanks . The crabs are waiting!
