'86 Tohatsu 55hp new impellor, still problems, now what???
jonbec
Bought used boat and came with Tohatsu outboard last summer...still haven't got the cooling system running properly. I replaced the impellor, "by the book". Water pumps out while motor is cranking over and then stops pumping while motor is running. Thermostat seems fine.... any thoughts????
pvanv
Re: '86 Tohatsu 55hp new impellor, still problems, now what???
Where did you find an obsolete impeller for that model? Is there a piece of debris in the base casting?
TOHATSU GURU
There is a guy in Australia that claims to be making impellers, plates, housings and liners for these...I'll believe it when I see it:)
