Hey guys,
I've been collecting any numbers and info I can find on the boat.
Cruisers Rogue 2120 GM 350 5.7 litre MCM 260HP LH Alpha One
Engine serial number from plate near the starter - B837322
Stern Drive serial number - Kinda faded, tag gone
Carborator make and model - Rochester Quadrajet
Water/Seperator filter number - 35-802-893T
Alternator model - Old lol, 1 wire
Spark Plugs - AC-MR-43T
Spark Plug gap - 035
Transom Assembly - OB868157 - found on a plate on the port side valve cover
Drive Unit - OB885_ _ unable to read the last two numbers - found on a plate on the port side valve cover
Carb Tag - Merc 260 1347-9662
Quick questions,
1. The plate on top of the carb says Thunderbolt ignition. From what I have read there are different kinds. How can I tell what kind I have?
2. Is a Thunderbolt ignition a rotor and points or is it electronic?
3. Any other related info you guys see or think I should locate would be appreciated
Thank you
Quick questions,
Thank you
