thirdtohatsu
- Jun 28, 2011
- 9
Hi all,
This is my third tohatsu and it has been running very nice for 5 years now ( 5 summers in use, first summer was 2007) It has always started right away, well it is served pretty good every year) Yesterday it suddenly lost power, after some testing we noticed that the upper cylinder was dead. Cables checked, coilleads swapped, new plugs, the upper cylinders fuel injector was flow tested at dealer and was ok. If you trim the motor up then it starts better and it seems that even the first cylinder is joining abit. We were thinkin if some water gets into the cyl when trimming down but same thing happens if you do a quick waterless test on the trailer. If the motor is off for about 10 min+ it starts better also. And a odd thing is that if you remove the killer and turn the key and start starting and put it back it starts alot better and the first cylinder is running for a very short time then dies. When its running uptrimmed (1st cyl missfires maybe abit) and then when you trim it down in idle it dies. Could it be some airflow, or air injector problem to the first cylinder or some sensor or what? Fuel seems ok and ignition, maybe the coil anyway allthough the spark seems ok...
Need todo a compression test next on all cyls. Thanks for reading.
