1977 Mercury 850 lower unit compatibility
I need to know if the lower unit from a 1973 Merc 85hp will work on my 77 merc 850. I have serial numbers for both if needed. Thanks
Chris1956
Re: 1977 Mercury 850 lower unit compatibility
It will fit. You might check the gear ratios. The '73 gearcase is 2.3::1. The '77 gearcase may be 2.3::1 also or it may be 2::1. You made need a prop change if they are different, but only trial and error will determine if that is necessary.
Faztbullet
It will work as all the 4 cylinder engines of 75/80/85 hp use a 2:3:1 ratio....
micky d
hi guys, sorry to open this a year later, but i was wondering if a 90 hp blueband gearbox will fit an 850 thunderbolt head?
thanks in advance for any info..
cheers Mick
Faztbullet
It will bolt up but the gear ratio is different....it will be slow out of hole as engine cant spool up even if you drop pitch. Been there done that...
