4 blade prop
boatnut74
Im looking into getting a 4 blade stainless prop for my 19' galaxie tri hull boat. It currently has a 19x14 1/4 pitch stainless thats tops out at 39mph at 5100rpm. Reccomended rpm is 4400 to 4800. The 3 props that are available are the solas rubex, salas hr titan and the quicksilver typhoon. We do alot of water sports and heard a four blade would work good. Any suggestions on what one i should get. Any other suggestions on different pitch would be great to. Thanks.
SparkieBoat
Re: 4 blade prop
a 19 pitch four blade should give you more hole shot and lower your WOT RPMs. although considering your are going above your RPM range with your 3 blade you may not see a noticeable difference. trim tabs will also help a lot with hole shot
boatnut74
Re: 4 blade prop
It already has trim tabs, sorry I forgot to mention that. It already does excellent on the hole shot and planes out decent. If were trying to ski at a lower speed it takes alot longer to plane out. I think I read somewhere a 4 blade would help with planing. I'm just curious wether a 4 blade would help wth handling and getting my rpm's where they need to be. I also have a 21 pitch stainless 3 blade but havnt tested that yet as we have been doing alot of water sports. I'll try to put that on soon to get some new numbers
SparkieBoat
Re: 4 blade prop
the 21 pitch would get you down to your max recommended rpm range, but you will lose some hole shot. If you can find a used 4 blade 19 pitch to use as a test that would be great. then you would know what you have.
