Hey All, New guy here Just picked up a 1977 Glastron v174 with a AQ130D and a 280 drive and need some advice. I am new to boats but not to engines, this is causing me some issues because I can't drop it in the lake to test it out every day. First I will tell you the work I have done so far. Needless to say I picked up this boat in less than perfect condition to say the least. When I got it there were a few issues that I needed to address right away, but I saw it run so knew that I could tackle them. First, there was a damn cheese cloth rag in place of the gas cap, so I had a tank full of crap, I completely drained the tank, and cleaned out the tank and all lines. I also rebuilt the fuel pump and installed a backup electric inline, and replaced the water seperator presently fuel flow is awesome, the bowls fill quickly. I also broke the solex 44PA carbs down to parade rest and did a complete cleaning, the gaskets were in good shape so I was able to reuse them. They both appear to function correctly from my experience with carbs. I also replaced the plugs, and checked the wires. The cap and rotor look less than desireable, a couple cracks in the cap but not too bad. The bosch distributor looks alot like a .009 used in old Porsches so i am very fimiliar with them, cleaned the points and checked the weights, seems to work fine. I have checked to make sure I have the plugs in the 1342 order correctly and they are. So to recap, I have gone through the fuel system and the ignition system, they both seem very basic to me, I am probably way off base by saying there isn't too much to miss on them. Now to the problem.
The boat starts beautifully in my yard, runs smooth with no popping or missing at all sounds perfect. I am pretty sure that the timing is damn near dead on without even dropping a light on it by the way it starts, it catches right off dependably, even when cold first thing in the morning. When I drop it in the lake, she starts up great and accelerates up to about 2000 rpm to get out of the no wake zone with zero issues, then the confounding part. If I have only 2 people in the boat it will eventually plane off at about 4000 rpm (31mph) it takes about 2 or 3 minutes to get there, there is a slight hesitation about 1/2 throttle but pushes through with no problem. If even one person is in the back of the boat, it will never accelerate over 2500 or maybe 3000 (10mph) and forget having more than 2 passengers and going over ferry speed. Once I had it briefly get up to 25mph with 3 people, but all of them had to be in the front half of the boat. I am no expert, but this is no 130 horses pushing this boat, I would say it is about 50 if that. I have not put a compression guage on it, but there are none of the signs of poor compression, and no sounds of valve slapping when it runs, so I am not convinced that the problem is deep in the engine.. any suggestions? Experience with this problem? Thanks in advance for your help
