No power from my 1965 75 hp sea horse
mgolding
PLEASE HELP!!!!!!! I have 1965 Johnson 75 hp Sea Horse outboard (V4AL-17S). My top speed is 10mph. I have drained nad put new gas in the tank, I have changed the plugs, checked the reed values, rebuilt the carb, cleaned and verified the gap on the points, checked to ensure fuel and spark were at each cylinder, compression tested each cylinder - all cylinders read the same (90 psi), and replaced the inline fuel filter in the fuel pump. However, when the engine is idling it runs fine - when we pull the plug wire from each cylinder the no 1 and 2 cylinders have no noticeable difference in how the engine runs but when we pull the plug wires from cylinders no 3 and 4 there is a major difference. We are at our wits end ..... we are leaning towards new points cap, etc .... any ideas --------PLEASE HELP --------
Monte1961
Re: No power from my 1965 75 hp sea horse
Are 1 and 2 on the same coil? You are on the right track. Check point/s check coil/s and condensers. chime in if you need any more help and welcome to iboats.
F_R
That's a bit odd. One set of points fires #1 & #3, the other fires #2 & #4. Likewise for the two carburetor barrels. Are you counting the cylinders from the top, zig-zagging from side to side? (You should)
The only other thing I can think of is the plug wires may be mixed up on the two non-firing cylinders. Firing order is 1-2-3-4.
Monte1961
This is going to be interesting!
