I have a 22 foot Sweetwater pontoon with a 2007 90 horse evinrude e-tech. It has a 13.5 x 15 aluminum prop and runs maybe 20-21 mph (as per the gps). Max rpm is about 4700-4800. I'd like to get a little more speed by changing the prop. I have to check my prop p/n to see whether it is a cupped or un-cupped prop. E-tech book says it should run about halfway between the normal range of 4500-5500. I'd like to raise the rpm's by maybe 500. Would maybe a 13.5 by 13 prop help? By the way, all numbers in this message are with 1 person aboard and clean (not polished) pontoons. I use a/c coil cleaner to clean them.
