I have a 73 johnson 65hp that won't go over 3500 RPM. The stator tests good and the carbs just had a fresh rebuild. I just replaced the rectifier due to the insulation on one of the wires was getting pretty weathered. I know for sure it isn't the Tach or the Prop. I used to run 5K on the RPM easily. The motor will hit 4K for a moment and then it kicks back down to 3500. I tried a lower pitch prop also and it still only hit 3500. The primer bulb stays hard and I have an electric boost pump that doesn't change anything. I am thinking that I have a power pack issue but I am not totally sure how to ops check it without buying a bunch of other expensive tools that I won't use often enough. I have a factory service manual and it really doesn't say much on testing a power pack with a conventional volt meter. I am just debating whether I want to drop the hundred bucks for a new pack or not. The motor starts great and will run all day at 3500. It is sluggish at getting to plane though. The hull is not saturated either. Just finished new transom and stringer job (will never do that again). Any ideas would be greatly appreciated.
