Evinrude outboard - spitting oil
Dondo
My Evinrude motor start spitting out oil/grease from the propeller area. Can anyone tell me what this might be from? I do very little work on the motor so not real good at this.
The motor is older.
fireman57
Re: Evinrude outboard - spitting oil
It would help to have a model number but if I had to guess I would say you have some fishing line or something in your prop seal. Take the prop off and see. If it is bad you need to replace it. Also, check your lower unit oil and make sure that it is not milky. If it is water has gotten in.
Dondo
Have to check on the model number - but yes we did find some fishing line. How do you replace the seal? Is that easy to replace?
fireman57
really need the model number but if you get the prop off you can probably figure it out. Do you have any idea about what year it is?
Dondo
It is a 1996 48 hp model # E48ESLED SPL
