This engine came with a sailboat I purchesed about ten years ago....never used and has been in my attic ever since. Pulled it out this week, as I plan to finally launch the boat...!
Only to find, naturally, that something is amiss. Shift lever wont budge....seems to be in Forward, though the prop spins freely. Also, the recoil starter wont engage, perhaps because the thing is in gear..?
I have a manual somewhere, but I could spend all summer looking for it, as it got packed up a few years ago when we moved. What a lousy alignment of the stars...!
Anywhoo....can someone tell me the easiest way to start looking into this. My instincts say check the linkage under the cowl first, but I'm not sure how to get at it (the linkage, not the cowl..!). Or, could the problem be further downshaft? And, if so, does that mean removing the lower end?
I should mention that, other than this problem, the engine looks well taken care of....clean and plenty of grease where it should be. Used in saltwater, tho, it may just be some minor corrosion impeding the movement.
Thanks for any assistance.
