bruceblaisdell
- Jun 27, 2011
- 2
HELP, I replaced the waterpump, thermostat, spark plugs before using this motor. We took it out yesterday, ran GREAT for 10 minutes, was peeing good at first, then we heard a low squealing noise and then peeing water turned intermitant. I headed back but motor shutoff and was VERY HOT and frozen. We got it back, and after it cooled down became unfrozen, we started it on ear muffs, and did not pump water (I didn't have a tank to run in). Took off lower unit, and water pump looked fine. I took off peeing tube and blew in while holding intake tube (from water pump) to see if there was a clog. CRAZY, when I blew in peeing hole tube while holding thumb on intake tube from water pump, was easier to blew in then while not blocking intake tube (you would think it would be the other way around easier to blow in while not blocking intake tube). Can anyone help?
Forgot to mention, we pulled the sparks plugs (no water and looked fine)
