are you overheating or is the horn going off. Since you disconnected the ground the sensor does not sense oil in the tank, the same warning horn sounds for low oil. if you can put your hand on the engine for 5 seconds and not get burned you are not overheated, if the engine is very hot to the touch then you have a overheating problem. when is the last time you changed the impeller:facepalm::facepalm:for everybody info, on one of the screw from the oil tank is a ground cable from the OIL LEVEL GAUGE and I didn't put it back. Now I put it back and is not overheating. Do somebody know why this cause the overheating, maybe a stupy question for you but please let know why
