On Friday I was idling into a slip and hit an underwater concrete slab. I have the Volvo Penta 5.7 GS. The engine cut off and I can feel a small chunk missing from the skeg. I know the volvo pentas have impact protection but I want to pull the boat out of the water and inspect the entire unit. The prop is not damaged so it looks like the skeg did it's job of protecting it.
What are some areas and things I need to check when the boat is out of the water? Should I drain the outdrive oil and inspect it for metal shavings? The outdrive runs fine but I just want to inspect anything else that may have been impacted.
Thanks for your help. This is my first boat and have learned a lot in a short amount of time!
