Re: 1954 10hp johnson
I am having a similar issue with my '57 18hp. I connect the fuel line, pump the primer button on the tank until it gets firm, then when I start the motor, it runs for a few seconds and dies, sometimes backfiring. I pump the primer again and the same thing occurs.
I rebuilt the carb last year so that shouldn't be an issue.
When I pump the primer button on the tank to build initial pressure and once it starts briefly then dies, the tank doesn't seem to remain at pressure as when I open the cap there is no pressure release.
I would think that unless the motor stays running to pump air back into the tank to keep the tank pressure up, then not having pressure in the tank after a brief start is normal. Yes? No?
