A couple of weeks ago I went to try to start the motor and it would not start. Engine turns freely and spark is blue. The oil/fuel mix ratio for this engine is 50-1. I recently purchased a cup that shows exactly how much oil to add to a 6 gallon tank. Approximately 16 ounces if my memory serves me correctly. After quite a few tries of attempting to start motor, I gave up but noticed that this same part of the exhaust housing pictured in this link was dripping what appeared to be excess oil along with fuel. After letting the boat sit for about a day, I went to try to start it and it fired right up. After letting it idle and warm up, my buddy and I decided to take it for a spin on one of the local lakes that we camp at. Everything was good until about 5 minutes into the ride. We were heading back in at WOT when the engine just died right in the middle of the lake. I tried starting again and no can do. Same behavior as day before. It is worth noting that the engine response when the engine is running is flawless. The motor runs and sounds like a formula 1 race car. After being towed in, I raised the motor and out came more oil and fuel. So my question is this. Is it possible that even at 50-1 these older motors were supposed to run a little lean...meaning less than 16 ounces per six gallons of gas? This boat came straight out of a time capsule. It literally is like new except that it pretty much sat in a garage since 1977. I'm thinking that it's a fuel issue. Should I try running with less than 16 ounces per 6 gallons? I suppose I could try and open the fuel filter housing and take a look at that.
Any ideas on what I should be looking for would be greatly appreciated. I would really like to have it on the water for July 4th weekend.
