I'm rebuilding a pair of DP-E transom shields and need some advice.
I am having a problem removing the steering fork seal, the one that seals the shaft at the opening. Here's the schematic (#16 in schematic, part number 977313):
http://www.volvopentastore.com/Shie...*****.921289913--store_id.366--view_id.768001
The seal appears to have a metal backing and is pressed into the transom shield, am I correct? How is this removed?
Also, when installing the bushings, do they need to be dry or should I coat them with grease?
