Lil' Rhody
- Sep 2, 2009
- 65
OK, have read most of the milk shake looking mixture water in oil horror stories but haven't come across this scenario.
Engine running good on muffs, slight knocking noise from lower end.
Shifting and all throttle operations performed fine
140psi compression across the board
Temp nice and low well within the green band
Oil pressuire @ 40psi
Oil looks fine on dipstick but maybe a quart to much in pan yesterday
After 2-3 minutes oil began seeping out aft portion of engine losing about a half quart all toll
Small amount of water spewing out from around timing cover
Location of oil leak near RMS and front water spray appears to near FMS but not 100% certain without pulling engine...
Don't mind performing a seal job but need to know if block being cracked could be causing leak and I should just purchase a reman and swap parts over..
