I'm a bit stumped. E150GLERV - '94 Evinrude 150 Intruder that I just purchased I did a Link/Sync on.. Everything was fine except idle timing. The idle timing tab is as advanced on the base as possible but I am at about 2 degrees ADTC. This was checked using a timing light. Analyzer is coming this week to verify my readings but if they are correct how do I get a couple more degrees of timing when there is no more adjustment left. Idle in the water is a bit low - 500RPM in gear. Thanks for any replies.
