My last impeller had self destructed and lodged chunks of itself up in the water tube that's up above the impeller. I used a coat hanger to sorta "roto root" the rubber and other material out, and quite a bit came out. The boat ran good for two trips but today it quit pissing like it should, the stream is very poor again. I think when I dropped the lower and replaced the impeller I pushed some compressed air backwards through the system and temporarily dislodged some debris or salt, and then after running a while they came back to where they were. Where is the thermostat located and could a blockage here be causing this issue? If that doesn't clear up my issue, what do I do at that point?
