Aluminum boat flooring
Pecar
I just recently purchased a 12ft aluminum boat, i was thinking about installing carpet. What should I use to attach the carpet to the aluminum?
Thank You
-Pecar
Bob_VT
Re: Aluminum boat flooring
Welcome to iboats.
It will not be as durable as you think....... However.... if you must..... home depot sells 6700 indoor outdoor adhesive which will work.
Many people have made removable wood decking to "level" things out.
Check the restoration section and see what other's have done. Look at the completed project section ;)
