Re: 85 HP Johnson 1978 Trim works properly going up, but will not go down
I am able to get the motor down by releasing the manual valve.
There was a slight leak at the valve, but there was no snap ring on the pieces so I removed to drain the cylinder and view the o-ring which was in need of replacement.
Other than the O-ring and refilling the cylinder, where do I need to go next?
Thanks,
