captwanabe
- Jun 21, 2011
- 19
so far i have replaced all fuel lines, rebuilt fuel pump, bought new carbs, new power pack, plugs, plug wires,i have a even 105 psi in all cylinders,in line fuel filter, when i went to buy the motor the guy ran it on a bench and it ran perfect, 2 months later i mounted on my boat. i spent about 6 months re-wiring the boat and a few other things went to finish with the motor now all is done and when it idles it starts missing to the point it kills the motor high rpm it sounds good, i dont see any case leaks, i have had a hard time with the recirculation routing cant find any diagrams there are four barbs on each of the cylinder sides and four on the carb. case i was told to "y" the top of the two top barbs to the bottom carb side barb and same with bottom barbs to the top barbs on carb. case i dont know if it right or not or if that would cause the problem?
