sw33ttooth
- Apr 24, 2011
- 498
omc cobra
351 ford 5.8l
15x17 michigan wheel aluminum its thick and dull no sharpness
wot 4000-4100 rpm speed 38-40mph
15x17 michigan wheel prop. 011007 stamped on it
1991 four winns sundowner 225
trailer and boat wiegh 6200-6300lbs so about 5000 lbs boat
bernett hydralic trim tabs
maximum wot is 4000-4400 so i cant go much higher.
i pulled the engine housing tonite 4, 1 inch ss screws, and i do not see any stickers on the block or heads and ect. stating horsepower. i found a patent sticker and an omc sticker with model and serial numbers nothing else but some random stamped numbers on the block.
to me the boat feels sluggish at 40 mph with a 351, the hull is dry and prop is free of major damage i know this is more of a heavy cruise around the lake boat more then a 70-80 mph speed demon but i would think 50,mph would be obtainable wouldnt it?
not sure if this will help any seen some one else post the gear ratio
gear ratio overall 1.41:1[.71]
upper 21:16
lower 14:26
from my booklet that i got when i bought the boat.
351 ford 5.8l
upper 21:16
lower 14:26
