91 Mercruiser front 2 cylinders not firing
Im going nuts here!!!!!!!
Took the boat out on the water today, running great and then NOT. It sounded like some one just unplugged a couple of my plug wires???? Took the thing out of the water brought it home and started testing. While the boat is running i pulled off the front to plug wires and no change. so i replaced the plugs . Still nothing. Pulled the wire put another plug on it fired the boat it has spark but weak. The back to cylinder are firing great, good blue spark. Compression is 150 in both of the cylinders. Any help would be great. If i cant fix this i think im gonna pull the plug and give lake ontario a new reef. HAHA.
Jesse:mad::mad:
dubs283
Re: 91 Mercruiser front 2 cylinders not firing
have you looked under the cap??
maybe some corrosion or other issue there
NHGuy
If the cap & rotor are OK put on replacement wires.
I replaced the wires and it still did it.. im gonna get a cap,rotor, wires and points and see if that helps. it was just odd that it happend that quick
Jesse
Pete104
What's compression on the 2 that aren't firing?
Ayuh,... It'd be Nice if We knew WHAT Motor yer workin' on....
Does anyone out there have any advise as to what could be causing this!!!!!
Jesse
dubs283
did you look under the cap??
perform a tune-up??
you have been given advice, we can't tell from where we are if you have performed any troubleshooting or repairs
