This is just the info I've been givne or have found
1999 Baylinr Capri with Mercruiser 4.3L Thunderbolt Ignition (sn 0L323553) with an Alpha One drive (sn 1.81R)
Just got the boat back from my wife's family, it has been in the garage all winter.
Back at the in-laws; clean up the boat (asthetically) reconnect battery, put fuel in the tank, check the oil and it should be ready, I'M TOLD.
To the boat ramp (I didn't disconnect from the trailer because of this...)
Key in, turns over fine. Plenty of cranking power.
Blower works, lights, etc.
Fires and then dies as soon as the starter disengages.
With the throttle up a bit (just above idle) SAME
With the throttle quite a bit higher, SAME
Suggestions.
Connections are all good. (visually)
Bro-in-law has no ideas as all he says he did was disconnect the battery.
Thinking...
Spark plugs? Distibutor...
Ignition system?
Thanks in advance.
Suggestions.
Thinking...
Ignition system?
Thanks in advance.
