Re: Gear Oil
As RedRanger said, the manual specifies that you drain from the bottom plug and fill from the middle plug. But I think he may have put where you pull the dipstick out of order.<br /><br />Place the drive in the down position. <br /><br />Remove the bottom (drain) plug and dipstick to drain (yes, sounds like you're refering to the correct place to access the dipstick). After oil has drained completely, replace oil drain plug and tighten securely.<br /><br />Remove the fill (middle) plug, and fill until the oil level appears at the mark on the dipstick. Check oil level with dipstick cap resting on top of the hole. <br /><br />Securely replace the dipstick before removing the filler from the gearcase. This will create an air lock and will hold the oil in the verticle drive until the oil fill plug can be securely replaced. <br /><br />Don't know that there would be any problem with filling from the bottom until it reaches the fill plug and then switching to the fill plug and filling the rest of the way from there, but it would be an extra step. <br /><br />What I do know is that you shouldn't just fill completely from the bottom drain plug!!! The following statement is from OMC: <br /> <br /> When filling the Cobra with gear lube, use the middle fill plug, as shown in the Owners' Manual. Do not fill through the (bottom) drain plug! If you fill from the wrong port, you will probably trap a big bubble of air inside the vertical drive, and that bubble will eventually rise to the top. When it does, the upper gearcase gears will run dry, and self-destruct. <br /><br /><br />Either way, suggest if it's the first time you're doing this you check the fill level before you drain to make sure it's full, then measure the amount of oil you've drained and compare that to how much it takes to account for any possible air pockets. <br /><br />On my '89 4.3L the specs call for 64 oz.
