Atchison0341
- Jun 9, 2011
- 3
Ok real quick here is my story. I bought a 1989 Sea Ray with a Mercruiser while I was stationed up in North Carolina, I was in the Marine Corps. I bought the boat and it ran fine, and when it was time to winterize, my father drove from Texas to get the boat and have a guy he knew winterize it. I have been so busy just getting out of the Marines, that I am just now getting things ready for the
boat.
I would like to get a manual on the engine and I have the engine code which is 0c462492, the code was located on the cover over the flame aresterator. I have searched high and low for any info on this engine and can't find any! Any help would be much appreciated! I have a good knowledge of car engines and thought this couldn't be much more complicated than working on a car.
EDIT- the tag on the side of the block says the engine serial number is 0c547332
Also on a separate note, I have began to tinker with the engine a bit, took out the plugs (need replacing) and took off the distributor cap( needs replacing) and the rotor button( need replacing) as well as the thermostat( it was rusted like no other!) I'm trying to find a good place to buy parts or even get part numbers from, because as I understand, the engine is nothing more than a 3.0 GM block, and with me working at Advance Auto Parts, I figured I could cross some numbers and use automotive parts. Is this possible? If so, if anyone can help, I'd be glad to cross numbers from advance and share them with everyone.
And my final question is, I've done lots of reading about winterizing your boat, however as I said a guy did it for me while it was in my fathers care, and now that I have it back, I've checked all my fluids and there are NONE, no oil, power-steering, nothing. I asked the guy and he said he couldn't remember if he took them out or not, I see no oils in the hull, so would it be safe just to refill all the missing fluids? And I feel like an idiot, but I can NOT for the life of me find where to put the anti-freeze, does it even need it during the summer time? Because as I understand the engine has a water pump that helps cool the engine.
I apologize for all the questions, this has just been so frustrating, I have lurked the forums for weeks now seeking answers and have come up empty handed, any info or advice would be very helpful! I'd love to get it on the lake atleast one time this summer!
Thanks,
Charles
boat.
Thanks,
Charles
