Re: 1993 60hp Johnson outboard
Compression checked out to be 125 on all 3 cylinders. The motor runs like a gem up to or around 2000rpm, but begins to shake and choke as if it has a rev limiter, which it does not. Dont believe the timing to be off because of how smooth the motor runs in the lower rpm. (A buddy of mine has a 2007 Evinrude and demonstrated the rev limiter and my motor behaves the same way; purrs, but once it reaches 2krpm or so, it shakes and will not go higher.
Anyone know how to test the stater, or any other ideas on what it might be? Will a thermostat limit the motor that way or cdi box? Anyone know how to test them to make sure they are operational?
No alarms sound at all during the motors operation.
