Re: 2 inch hole fiber glass repair
... but the back up piece and the patching method and the cloth IS how you you fabricate the patch .... I'd recommend usin Epoxy since it is a much better glue than poly..... before final gelcoating ......, fair and gel coat...
Um..no..You cant use epoxy for the repair..then Gel..
You dont need the inside lams for this repair...
You only need to build it up with 1.5 oz mat on the outside ( NOTHING MORE ) .. then fair ( for that small of a hole its not even required that you use any fillers for the shape.. just glass ). We are not talking about Below the waterline and its only Cosmetic.
** Using
Poly Im gonna give you a Trick of the Trade Thing here shhhh **
1. Grind and feather your repair ( about where you have the gel sanded off right now )
2. ACETONE wipe.
3. Tape ( Yes Masking tape ) across your repair on the Outside ground out repair.
4. Get a nice New razor blade and cut the tape about 1/4" around the hole.
5. Mask off your circle repair with tape..then Tape/mask just under the repair zone so resin does not dribble down the side of your boat ( masking or taping newspaper just below the repair area works Great ).
6. Lightly resin coat over the repair.
7. Rip your 1.5 oz mat into little 2-3" circles ( Yes I mean bye Hand Rip your mat into little circles with no hard edges .. kinda little glass feathers all around ).
8. On a small piece of cardboard wet out about 4-6 little hand ripped circles of mat.
9. Pick up that layered mat lam and gently place it on your repair..gently on the middle because you only have tape for your backing and hand ( your using latex gloves of course ) kinda work that repair so its nice and smooth ( a bubble roller will really help at this point if you have one ).
10. Let that kick off..sand and fair..( should be to the shape of the repair and Solid glass with no bondo).
11. Light spray your gel..then smear around with a spreader to fill the pin holes. Then spray 3-4 coats as needed.
12. Sand and buff.
Bobs your Uncle
One day Done in weather like this..
YD.
