country moose
Thread starter- Joined
- Jun 23, 2011
- 2
hello all i have a 1965 merc that i put new plugs in and when i removed plug 1 it was smashed so i put new plugs in all 6 and was running ok fixed a couple wires and seemed better. took to local fishing hole and started it and it sounded like someone throw a screw driver in the engine and then turned it off anf started again and ran fine. so i bring it home and put the clamp to clean motor and started it and it was runnin fine then all of a sudden that noice again and then nothing. i tried starting it and it makes the sound to start for maybe half a sec then nothing. took off top cover of engine and was able to manually turn the crank shaft. what happened please help thanks eddy
