Hi everyone,
I did a search but could not find specifics for a 50hp so I thought I would ask ..
I need to replace the water pump/impeller on my motor (Parts are in the mail). I wanted to get a head start last night and I attempted to remove the lower end/gear case. I removed all the bolts/nuts and was able to get the lower end to drop about an inch but it seemed to get hung up on something.
Reading some other posts it could be getting hung up on the water tube that connects to the pump?
I have also read some posts were the shift linkage is mentioned, I did not remove any bolts connected to the shift linkage, is there a separate location where I need to disconnect this? I have looked at some service manuals online but I could not find anything specific.
Does the motor need to be in forward gear to remove the unit or is neutral fine?
Does this motor have a thermostat?
Thanks
Shawn
Thanks
Shawn
