cwcollins06
- Jun 21, 2011
- 53
I've got my grandfather's boat and I'm finally getting around to restoring it. It's a 17' 1977 Tri Hull that I'm pretty sure was an Invader Capri hull purchased bare and customized by a boat shop other than Invader in Giddings, TX. I took it to a shop that came very highly recommended by some friends of mine but he outsources his glass work to someone else locally. I got the contact info of the glass guy and I intend to call him to see what his process is so I know what's going on with my boat. I already got permission from both shops to drop by the glass shop to inspect my boat while the work is going on and they readily agreed that I could do so (made me more comfortable for sure). I'd like to know what questions I need to ask to be sure the work is being done properly. I assume from what I've seen here that there's no way they can do the stringers, transom, and deck without pulling out all the old foam, but can they put the old foam back in or will it be so damaged that they have to replace it with new foam? Obviously I want it to be new foam.
I don't have any reason not to trust these guys but I've always been a "Trust everyone but lock your doors" guy and I want to do everything I can to ensure it's being done correctly.
