I have a 2002 Bayliner 185 Capri that came with a 500gpm Johnson pump wired to a two position on off switch. I purchased a compatible Johnson automatic switch to attach to the pump. The auto switch has 3 wires. All of the Johnson diagrams so it wired to a three way switch, not a simple on/off switch. The boat is in the water 24/7 for the summer. Should I wire the auto bilge switch directly to the battery & pump or will this mess with the on/off switch at the control panel?
Puzzled in Lake Arrowhead.
