Re: Original prop?
No such thing- it's a guess by the dealer usually. The selection is made using several factors including expected usage, load, speed desired, RPM range, blah blah blah. Is the "factory" prop still on the boat? The barrel may be stamped with the numbers or it could be on the hub under the nut.
