tmfeaster
- Jun 22, 2011
- 94
I recently purchased a 1998 Four Winns Fling used from a second owner. All the information I can find from Four Winns, they never made a 98 but the registartion/title and all shows 1998 with the DOT.
Either way, I assume it has a 115hp OMC 2-stroke outboard turbojet engine. I have the manual to the boat but not the engine.
1. Does anyone know where to find a manual on this engine? I need to test the stator/power pack and most likely replace them.
2. What should the top speed be? When I am the only one in the boat, it gets on plane fast and speeds up to 35 quickly, sometimes I can hit 40 after moving on non-choppy water.
When my wife, 2 kids and I are in the boat I can only top out at about 25mph and it is tougher to get on plane. It is also difficult to turn right with all 4 of us in the boat, and when I do it slows down to about 20mph. Is this normal or do I need to start looking at something that could be bogging down the performance of the engine?
I mix 2-cycle oil 50:1 (16oz per 6 gallons) and recently put some additive to remove ethanol from the gas and also some carberator cleaner additive to the gas. I mix the oil because the alarm system on the oil injection mixing system was broke so it was easier to mix than to replace that unit.
It needs new plugs, I hear Champion gapped at .030 is correct. Does that sound correct?
When the engine is running in neutral or idle speed.. it "coughs" or "misses" once and again. To me this could be the plugs, but I am not sure.
It is kind of a bear to start. I turn the key over one slot, push the key in about 4-8 seconds to prime, put the throttle lever down to idle (with neutral button in) and turn the key... to ge it started I have to pump the throttle down to full speed a couple of times and then it goes. It may die a couple of times, but then starts back up and once it gets warm it runs fine. Seems failry normal for a 2-stroke but this boat has been a new learning experience despite my years of knowledge using/maintaining a 85 Procraft with 150HP Merc Black Max.
One of the blowers is MUCH louder than the other. I assume this means the blower itself needs to be tightened, does this sound correct?
Sorry for the amount of information and questions but I from reading this forum there are many knowledable people on this site but some of my questions have not been asked by others.
