Hi;
I have a 1988 Force 50HP (507F8C). Took it out last week and noticed it takes longer to get onto plane (no trim/tilt). Also, top speed seems a tad slower than normal. Starts fine and except for slower top speed seems to run fine. What I DID notice is a loud shreiking noise as motor reached higher RPM (in gear). At idle and slow speeds there is no shreik noise. As engine gets up to about 2/3 throttle I start to hear it. At full throttle it is very loud. It sounds like when you use an air compressor blow-off nozzle and blow it thru a short piece of pipe. As I throttle back, the noise decreases and dies off at about 1/2 throttle. Not sure if deceased top end and this noise are related or not.
Anyone have any ideas please?
Thanx
Thanx
