250Gimp
- Jul 13, 2007
- 145
Hi all
I am hoping you can help me make some decisions about prop choice.
Current specs:
2006 Maxum 1800 SR3
Mercruiser 4.3l MPI, 220hp
Alpha 1 Gen II, 1:81 gear ratio
Mercury Bravo 1 prop, 48-831912 24P, 4 blade stainless (I don't know what all the numbers mean except the 24 pitch)
Max RPM = 4450 rpm @ 52 mph (on boat speedo)
The problem is it is slow out of the hole when pulling up a slalom skier, and the skier gets dragged a bit before coming out. I also have a lot of bow rise, even when not towing someone.
I have smart tabs, but have not installed them yet.
I have done some diggin on the net, and it sounds like going to a 5 blade lower pitch prop may help.
I saw a recomendation for a High 5, 21p for my boat/engine combo.
My question is, does this make sense for what I am trying to obtain? I don't mind loosing a few mph if the hole shot is improved a fair bit.
I have found a 23p High 5 used in my area, and am wondering if that will give me enough oomph just dropping 1" in pitch?
Thanks a lot for the help!
Current specs:
2006 Maxum 1800 SR3
