I have a 2000 johnson 70 2 stroke with a vro system. The motor had old fuel and bad plugs and caused it to smoke like crazy..so I drained the fuel in the tank and fuel line, and put plugs in the motor. Fires up right away and seems to idle pretty well but when you give the motor throttle you can tell the motor is breaking up. I'm not sure about the timing because theres two sets of numbers. Theres markings on the flywheel and at idle, the timing light is spot on with one of the marks....but as I understand it, theres a WOT timing mark that the motor needs to be on as well.
Mainly my question is what/how should I check to see whats causing the motor to break up to go about fixing it.
Thanks for any replys.
