redjmp
- Mar 16, 2005
- 536
My 86 115 elpto has always been somewhat loose at the bottom of the swivel pin. I always assumed it was a worn out bushing but after having a closer look, it seems the the swivel shaft has minimal play inside the transom assembly but the iron yoke that bolts to the leg has a lot of play on the bottom of the swivel shaft.
The yoke is not secured at all to the swivel shaft and the leg is free to move about 1/4" back and forth as the hole in the yoke is that much bigger.
What is missing here?
What do I need to do to get the play out?
