I have a 1984 115 V4 Evinrude outboard (E115TLCTE) which runs great under load, tons of power, but misfires and stalls at idle making docking very difficult. Plugs are clean, no fouling, even though problem has been like this all of last summer....checked all jets, new looking and consistent size (checked with closest number/letter drill as gauge)
I put a high speed digital oscilloscope on (DC clamp on measuring current on spark plug wire), and found Cylinders 1 and 3 fire together, and also 2 and 4.
My understanding was that there was a clear firing order of something like 1-3-2-4, but that doesn't seem to jive with what I am seeing. I also noticed that firing current was weak at time....barely firing at all on cylinder 1...
Swapped the two ignition modules....problem did not follow the module. Tested 12V to coil current versus plug current....they are consistently the same, but 12V pulse is sometimes dropped or weak.....
I also did diode test (good), and checked sensing coils with Digital meter....says voltage should be > 0.3V in manual, all I can see is 0.07V on all 4....wonder if using a DMM to record high peak volt (built in function) is different than the old fashioned analog meter in this respect, but this could explain why misfiring a low rpm.
Is it possible the magnets in the flywheel are weak or something else is going on that would make the firing weak at low RPM, but great at high?
Note that when engine backfires, it tends to blow water out of exhaust, and stop engine spinning dead cold. Another weird thing is that if I put into gear at idle, the random backfiring seems to calm or disappear.......this is also very puzzling)
Anyone have experience with this or could give me a few pointers?.....don't know what to think at this point....very frustrating. Dan
