max RPM 454
jsaylor
I have a 25ft daycruizer with a 454, what should be WOT (max RPM)
Thanks
HT32BSX115
Re: max RPM 454
Thanks
Howdy,
Welcome to iboats!
It will depend on what year your engine is, and whether it's carbed or MPI. Many carbed models are rev limited to 4700 and rated at 4600 MAX. Some of the newer MPI models are rated up to 5000 RPM.
Regards,
Rick
OldNBold51
Re: max RPM 454
my 95 wellcraft 23.5' with carb'd 454 won't turn over 4200, according to my tach. I'm pretty sure the cam profile is the issue as the boat will pull hard to 4k and just run out of rev and max at 4200.
HT32BSX115
Re: max RPM 454
If your engine is otherwise running ok and your tach is correct, you are probably over-propped.
