Re: 1971 18hp, flywheel wobble...
Well, the flywheel nut came off easily enough, so no idea on that [going to orange/blue box tomorrow to get bolts for flywheel puller].
It just happened as far as I know, I've had the engine for ~2 seasons, I water tested it early this season, didn't notice it then...But the engine lost a lot of power on the return trip and ran really poorly [I assumed either one plug/coil or carb problems] so I put it away, then on Sat I pulled the carb, cleaned it, re-installed it and started the engine..at that point I noticed the loose flywheel...
I'd rather hope it's a mis-torqued flywheel!
