Liopleurodon
- Jun 18, 2011
- 25
I have another thread started on general noob questions, but there's one area I'm looking to focus on in particular. That would be installing a 20hp motor on a boat that's intended for something much bigger. Specifically a fiberglass V or tri-hull with 6-8 person capacity.
The main reason would be to comply with horsepower limitations on certain local lakes. I am curious as to whether there would be any notable efficiency improvements due to the reduced weight, or losses due to the engine pushing something much larger than it was intended for. Particularly, would it stand a chance at all of planing? Or from another angle, what's the biggest boat/cargo that a 20hp motor could plane?
I'm also wondering if this would have a large effect on prop selection. I would think the pitch should be different depending on the expected speed of the boat relative to the prop RPM.
I'm not concerned much with speed, but am concerned with economy and range. Thanks all for the expert input and patience.
