capt. nautical
- Jun 20, 2011
- 3
RODBOLT
sounds like you are the man when it comes to troubleshooting these outboards...I have done some reading mostly your older post but I have not came up with a definate solution...
1. clean freshwater motor
2. fuel system fine, just clesned the carbs a few outings back and the ran beautifully...I was so proud...and then!
3. first this prob was intermittant as it did it once while I was cruising around at around 3000 to 3500 rpms. power went down and I limped back home. I noticed while power down that the tach had dropped to 0.
4. before I got all the way back she come to life, power back, tach back!
5. soon after she lost power and tach again.
6. loaded up headed home. next day on muffs, all power and tach. put new plugs in and hoped for miracle unfortunitely no miracle....
7. checked spark , identified that there is 0 spark on # 2 and # 5 plus no signal to tach.
8. the yellow limp enabling wire in the rear is connected well it makes no difference if it is plugged or unplugged she runs the same.
9. checked connections on the cps wires and same no difference if it is plugged or unplugged. so I do not know at this point, I was hoping 2 5 and the tach situation would make it stand out...I am leaning toward the cps but i feel like its in slow mode????would slow mode disable the tach?
awaiting feedback at this time....
Thanks in advance for any suggestions available
J
J
