briggs09hp
- Jul 20, 2009
- 24
Hello,
I have a 1995 Sea Ray Signature 200 cuddy. It has a Mercrusier 5.0 (2bbl 190 HP) and Alpha 1 outdrive. The boat weighs about 2900 lbs and I think the prop that I just had my mechanic put on is a 14.5 x 21 pitch. I had him put on a prop with more pitch because the old SS one was bent and I was also over revving. From my understanding the WOT RPM is about 4300-4600 RPM for my boat.
I just took the boat out today for a test of my new prop. The lake was nearly glass so it was very smooth (no wind). I took the boat both up and down the lake to take the current into account, but both runs were the same.
I ran a top speed of 48 MPH on the GPS at 4700 RPM trimmed almost all the way out. So my question is, should I go to a 22 pitch (one size larger)? I heard that every pitch size changes RPM by about 200 RPM, so I am thinking that would put me in the correct RPM range. Would going 1 size larger increase speed slightly? I am thinking if the engine has the power, it should be able to? Is 48 MPH fast, or about normal?
I am looking for speed and understand that I will lose some acceleration by doing so. When I tested the boat it was just me and my gear on board and a half tank of gas. I know if I put more people on I would slow down, but am I doing it correctly? Do you want to test props fully loaded, or the way I did it?
I feel like I'm right at the limit, and Im not sure what to do.
Thanks,
Matt
Thanks,
Matt
