Blowing Fuses, Mercury 9.9, 4 Stroke, 1996
trk12fire
I have a 1996 Mercury 9.9, 4 stroke and I keep blowing the 20 amp fuse. I just replaced my shifter cable, but I don't think that has anything to do with it. I took the boat on ruff water, maybe I shook something loose. There is a black wire under the engine cover that doesn't seem to go anywhere and another black wire that looks a little fried. Also, the fuse blows when I turn the ignition. It cranks for about 1-2 seconds, then blows. I've never had any problems with the motor, I just can't figure this one out. Any info is helpful. Thank you.
John
