merc120_81
- Jun 20, 2011
- 92
Hello All,
40 year sailer, newbie power boater.
Power is a Mercruiser MCM120 (I4 153ci) sn/5828###, stearn drive pretty sure, alpha.
she can idle/run slow all day(150/160F), but when I get on her to pull the kids on a tube, the temp climbs way too high (reads over near 210/220)
Purchased an infrared/laser temp probe as suggested in the forums, gauge is probably off, atleast 20 degrees. I have also purchased a generic temp gauge and sending unit to get an engine water temp with somthing new next time I am out.
Where should I point the laser dot on the IR probe, and what temps should I be seeing?
thermastat housing?
cylhead between the plugs?
temp sending unit?
Waterbox/exhuast/elbow/riser?
out hose to waterbox/exhaust/elbow/riser??
How likely is it that he circulation pump on this boat could be bad?
There is some pretty heavy corrosion when I take off the "U" shaped large cooling hose on the starbord side/front of the engine (my best guess, cyl head to water pump)
I have not done a test for impeller function with any measurement (bucket and running exactly at I believe it was 650rmp) but have pulled the cold water in, off, and it seems to be spitting quite a bit of water (underway idling on the lake).
I have replaced the sterndrive impleller, and thermostat. Impeller replacement was a kit, included gaskets, uperhousing, o rings, impeller. the old houseing was in decent condition a few scratches in the cup, but that was about it.
Running freshwater in Michigan, water temps around 65 to 70 F.
thank you.
thermastat housing?
temp sending unit?
thank you.
