stoughty
- Jun 20, 2011
- 6
A couple of firsts happened to me yesterday ...... 1st time this motor gave me any type of an issue since I've owned it. This was also the 1st time I've ever had to turn around at the launch ramp w/o the boat coming off the trailer. A very frustrating day!
Tried to take my dad out fishing yesterday for Father's day. Got to the ramp and backed the trailer in the water. While trimming the motor down, it just stopped. It was only about 3/4 of the way from being fully trimmed down. I tried to push the button again to trim the motor down (or up) at the throttle and all I heard was a "buzz" of some sort but the motor wasn't moving. I tried to lower (or raise) it using the button at the motor and had the same results (could hear a buzz coming from inside the cowling but the motor didn't trim/tilt). With the lower unit being in the water, I decided to try and start the motor. I turn the key and the motor did not turn over.
I took the cowling off of the motor and investigated. The "buzzing" I heard while trying to trim the motor was coming from the cranking motor solenoid. It seemed like the solenoid wasn't "engaging". All the wire connections are good/clean at the solenoid. I tapped on the top of it with a handle of a screwdriver (kinda like you would with a starter on a car when it won't engage) and I had power again! The tilt/trim was working and the motor would turn over. Thinking it was a glitch and that we'd be lucky and actually get to fish after all, we tried to launch again and the same issue happened again. I pulled the boat out of the water and took it home.
Got the boat home and did some further testing. The tilt/trim wasn't working again when I got the boat home, so we got out an electrical tester. We had power coming into the the cranking motor solenoid (from the batteries), but nothing coming out of the cranking motor solenoid (going to the starter). Once again, the starter will not turn over when I turned the key and the tilt/trim is not working (the buzz is still coming from the cranking motor solenoid when trying to tilt/trim). Again, I tapped the solenoid with a screwdriver and the tilt/trim was working again. My dad had the electrical tester on the positive wire coming out of the solenoid going to the starter and when I turned the key we now had power (and the motor turned over). So now we had power coming into the solenoid and power going out and everything was working (as before, we had power coming in and nothing going out and nothing was working).
After reviewing the manual I have for this motor, I found that the starter and the tilt/trim motor both get their power from the cranking motor solenoid. Multiple tests are pointing me towards the cranking motor solenoid as being the culprit. Do you agree? Could it be that I'm missing something else? Do cranking motor solenoids just go out on their own (go bad) ... ever? The "buzzing" I heard coming form the solenoid, is that usually an indication that the solenoid is going bad or is bad? Any help you can provide on this issue would be greatly appreciated!
B.T.W. - When I had no power going to the starter or the tilt/trim motor, everything else was working fine. I had power to the all the guages. The systems check would go through it sequence checks. As far as I know, I just didn't have power going to the starter and the tilt/trim motor.
Also, does anybody have a link for a replacement cranking motor solenoid? I want to get this fixed so I can take my dad out this Friday for a "make-up" fishing trip!
Motor Information:
1996 - 200 HP Oceanrunner
Model# J200TXEDR
Thanks in advance - Mike
Motor Information:
Model# J200TXEDR
